Read error using RS232
Unless you are trying to communicate to the same RadioShack DMM (and it does not look like you are), you do not have the same problem and the setting of the handshake lines will not do you any good.
Please provide the make and model of the instrument. Also, have you tried communicating in Hyperterminal? That was a recomendation early in this old thread. Have you verified the com settings and that you are using the correct type of serial cable? There are two basic types - straight-through and null-modem.
Also, you would not want to modify the shipping example like the image shows. I also have no idea what you clicked on to get that list of properties. It certainly wasn't the VISA property node.
Message 21 of 38
(2,041 Views)
Message 22 of 38
(2,039 Views)
That's one of the most unproductive responses I have ever seen. You did not answer a single question and I have no idea why you would circle the Wait (ms) function.
Message 23 of 38
(2,035 Views)
is it necessary to connect a cable to the Com1(RS232 with CompuLab)? I thought the simulation uses the buffer of Labview to read it out?
There is no more Error message in the Basic Sample since I use the new modified one with the readTimer. But there is no Read Output? Here is the error-debug:
Message 24 of 38
(2,032 Views)
I understand your worries. I'am a german beginner student and it is not too easy to know what you mean.
But I will try.
Best regards
Sabrina Bangert
Message 25 of 38
(2,027 Views)
You are still not making any sense to me. What the heck is CompuLab and what kind of simulation do you think you are doing. Posting the block diagram of a standard LabVIEW VI is not productive either. There is absoultely nothing to debug in that code.
Do you actually have an instrument connected to the com port?
Please fully explain (in words) what you are doing.
Message 26 of 38
(2,024 Views)
You could also write your post in German. I don't speak it but there are a large number regular forum users who do.
Message 27 of 38
(2,021 Views)
with hyperterminal you mean something like that? But how do I use in this hyperterminal the existing BasicSerialWriteAndRead.vi?I have no idea.
Message 28 of 38
(2,018 Views)
You don't use the BasicSerialWriteandRead.vi in hyperterminal.  If you have problems with a LabVIEW serial VI, you need to determine whether you can communicate with the device using a terminal program such as hyperterminal.  To be certain that your baud, parity, and stop bits are correct.  That you are using the correct cable (null modem vs. straight through) and whether you need any type of handshaking.  Do you need to send a special command?  Are there termination characters you need to send?  That takes any LabVIEW programming questions out of the equation.  Once you get it working in a terminal program, then you can apply that knowledge to make the LabVIEW program do what you want.
Message 29 of 38
(1,995 Views)
I use LabView 8.5. I did not connect any hardware device to the com ports.
1. For the first I only wanted to try out the exemple "BasicSerialWriteAndRead.vi".
2. But I get no read-output      --      (but no error message, nothing. It terminates after timeout without any message)
Message 30 of 38
(1,994 Views)
