Read datas from table
According to the code that you have made,Is it possible to fix a particular array index value as a constant one and also show that value as not changing after reading??Please answer.
Thanks as kudos only:)
Message 121 of 189
(772 Views)
Hi danil,
yes, that's possible: don't overwrite that array index with new values...
Message 122 of 189
(770 Views)
As we are appending the array with new values where to place the replace array subset?
Message 123 of 189
(767 Views)
Think about that yourself - you wanted to go through LV basics atleast for two weeks?
Message 124 of 189
(765 Views)
Hi Gerdw,
              I tried in the below attached way.But it is outputting the same value in all the array indices.But the value is just wired to the first index only.Please have a look at it.please give possible suggestions.
Message 125 of 189
(744 Views)
Here we are sending(writing) values before the array formation.So how can we fix a particular array index element?
Message 126 of 189
(739 Views)
Hi danil,
can you please explain what you're trying to do here:
That is the core of your "newone.vi"...
What is the goal of those string to array, replace, array to string dance?
Where is the place where you want to keep certain array elements fixed?
As told before:
- Go through the basics lessons.
- Before coding you should think about what you really want to achieve...
Message 127 of 189
(724 Views)
The input of "replace array subset" should be an array so converted string to array after fixing first element of the array with a particular element we have to input it into VISAwrite,so again reconverted to single string.
while sending I want my first element fixed and only others have to change.After reading also we must see the first element as fixed and others have to change.
This is what Iam trying to achieve.I won't ignore your advice of taking the basic course.But now in a busy schedule.
I attached only the writing(sender VI which is named as newone.vi) and not the read VI.
Message 128 of 189
(720 Views)
Hi danil,
"The input of "replace array subset" should be an array"
That's correct...
"so converted string to array"
That's not done correctly...
- You create a single string (your number, appended with LF).
- Then you convert that single string to an array of how many elements?
- Then you replace the 1st element of that array (with how many elements?) with a fixed value!?
- Then you convert that array (with how many elements?) back to a string.
- Then you prepend a different array (that probably is the one you really want to work with!) with that back-converted string element.
Again:
First think, then code!
I will not post any new VIs for you. I will only analyze your VIs for problems/errors, until I recognize some "real programming" of yours!
See it positive: atleast I don't unsubscribe from your thread(s)...
Message 129 of 189
(713 Views)
what I understand is,each time the loop iterates and new string values will comes and it will form the array.what you actually meant by how many elements?
Message 130 of 189
(710 Views)
