Read data of embedded web page
Hi Wilmer,
i have a question. Can you please explain why you use an embedded webpage, but you want to automatically login? I'm sure my posted example should work. It works for my. I only get error 66, but this is ok. Can you also explain what you aim behind all this is?
Try to help.
Mike
Message 31 of 37
(2,626 Views)
Hi MikeS81,
I have an electronic equipment, which I have to remotely monitor to capture certain data values and then processing them, equipment is located in a very remote and only has an Ethernet communications port, this equipment has a website Embedded, using Internet Explorer on my PC I can enter the site prior entry of the username and password, and see different data, I need to extract this data using Labview, it is possible to do this?
Message 32 of 37
(2,617 Views)
Hi Wilmer,
yes it's possible and you should be able to do it if you use my vi. If you have the correct username and password, then you should be able to get the result page. No need to use the activex Webbrowser.
Mike
Message 33 of 37
(2,609 Views)
MikeS81, If you want I could send you by mail, the username and password that you try it, maybe there's something I'm doing wrong, I can not post to this forum those data because it is private
Message 34 of 37
(2,600 Views)
Hi Wilmer,
you can send me a mail to this address.
007918097f20@910cc211f3e4.anonbox.net
It's valid til 09/17/10 11:59 p.m.
Mike
Message 35 of 37
(2,590 Views)
Hi Wilmer,
i made some changes on the vi and this works for me to get one of you pages.
Hope it helps
Mike
Message 36 of 37
(2,573 Views)
Hi MikeS81, Thank you very much for your help !!!, but I just did a test with the new VI (8.5)  you have posted and the Base64 that I've created but I can not enter the website, I think the error is in the Base64 that I'm generating, if not too much to ask could you send me or publish the "Util convert to Base64.vi"?
Regards
Wilmer
Message 37 of 37
(2,557 Views)
