Read data of a table control with visa
Hello, I have a problem with labview that I am trying to implement, I will explain a little about how the system works. I have a table control with run-time menu, with different options to fill the table, as if it were a sequential table of a process. The problem is, I would like to read the table after finishing filling, and from there, read via serial port (VISA), row by row, and that will send it to Arduino. Is there any way to implement that? I tried but at the moment without any correct result. Thank you!
(2,330 Views)
Here's my vi.
(2,325 Views)
Use a FOR loop to process each line at a time and send to your Arduino.
(2,288 Views)
