Read data from an acquisition unit at 1hz using modbus TCP
Hello everyone,
I am familiar with Labview but quite a beginner with numerical communication.
I will try to summurise my problem.
I use Labview 2018. I want to read the data from an acquisition unit with 7 sensors plug inside.
My program is not perfect but at this stage I succeed to read the 7 sensor with a frequency of 0.5HZ.
So all the  parameters seems OK.
When I try to read only two sensors, it reaches 1 HZ.
My last try are about structures, firstly I wanted to read my table with a structure "for" but I try to remove this structure to understand better and to see what's happening ?
I join to my post 3 VI and sub-VI and file result.
Is it possible to reach an acquisition at 1 hz or is the PC to slow to manage 7 sensor at 1 HZ?
Thank you very much,
I stay free for any further information.
(784 Views)
Hi adri,
It's not your PC that limits the execution speed, it's the way you created your VI!
I see two major issues ("numeric_7sensors"):
  1. reading 7 values in parallel over the modbus: you have a shared resource, so you need to read sequentially!!!
  2. reading those 7 values by using the "read single register" calls: as those modbus values are in a range of 0x04 to 0x31 you could read them in just one call by using "read multiple registers"!
Other issues:
  • Cleanup the block diagram to make the code more readable!
  • You can resize the IndexArray function, so you need only one node instead of 7!
  • IndexArray starts to index at element 0, so you don't need to wire any index constants!
  • There's no error handling for the file saving functions!
"numeric-7sensors-structureFOR" is even worse as you placed the 1s wait inside the FOR loop…
(761 Views)
Hello GerdW,
Thanks a lot for your quick answer. I am sorry for my code, I try to use all of your tips but I still don't manage the frequency. For now, with the last code I try to read using sequence structure, it does'nt work either, still at 0.5HZ. Your second idea was to replace "read holding register.vi" by "read multiple register.vi" but I couldn't find "read multiple register.vi" there is always the "write and read multiple register.vi", Does this VI exist ?
I think the answer is to use only one modbus tools to read the 7 address, which one i need to use.
Thanks again,
Adri
PS  : I am sorry for my code I amnot an Labview architect
(717 Views)
Accepted by topic author adri73
Hi adri,
Did I mention "sequence frames" anywhere in my message?
Why do you think using several sequence frames will make your code run faster???
As before: you can read several Modubus registers with just one Read funciton call! That's the way to speed up communication!
I don't have that Modbus library installed on my (current) computer, so you need to read the help for eaxch Modbus function on your own…
Me neither…
(700 Views)
You need to replace read-register(sous-VI).vi with one of these and read multiple registers at once:
Then, convert your data and keep the stuff that you are interested in, ending up with something like this:
reading multiple modbus registers and converting to floatreading multiple modbus registers and converting to float
(691 Views)
Thanks a lot for your help and your time.
I will try as you say.
Adrien Bonnefoy
(674 Views)
Hi, Thanks a lot for your time. The last VI works well, I did some minor adjustment and I understand better how it's working.
Regards
Adrien
(616 Views)
