Read daqmx unit property from a task
Looking for a way to read the units of channels in a task. Right now the only way that I know of doing that is to actually read data then query the data. In this instance I do not want to do it that way I'm looking to read the units from the task. I do have custom scales applied so I know that complicates things.
Message 1 of 8
(4,374 Views)
There is a DAQmx scale node that will give you the scaled units.  Go to the pallette  DAQmx - Advanced - scale setup - scale node.  You will have to break down the task into channels and then into scales.  Take a look around the pallette and you should be able to put something together.
Message 2 of 8
(4,361 Views)
Yes I have that setup but have not gotten anywhere. Not nearly as easy as some other properties to query. Any ideas based on the snag of the attached code. Element and CI.CustomScaleName return empty. Which obviously element will since the other is empty. The task is setup with custom scaling simple freq to RPM conversion including naming the output units.
Message 3 of 8
(4,356 Views)
Take a look at this and see if it helps.
Message 4 of 8
(4,346 Views)
Nice I like that I should have thought of that.  Must be something about using the project based task and scale that is diff that or the CI.  I'll keep experimenting.  Very interesting that it returns a blank array.
Message 5 of 8
(4,328 Views)
Accepted by topic author randy1815
How about this then?  You just need to dig out the scale names.
Message 6 of 8
(4,322 Views)
Amazing, Many thanks I can see this being used many times!
Message 7 of 8
(4,303 Views)
I realize this is an old thread, and that the OP accepted an answer as a solution, but I had a problem; this only works for custom scales and not the scales built into signal conditioning channels (like thermocouple, strain/bridge, or accelerometer input devices).  I made a solution (LabVIEW 2017 version) to what I felt was the larger problem, and attached it here.  I hope that some will find it useful.
Please use with caution, as I have not tested it with every permutation.
Message 8 of 8
(2,984 Views)
