Read avi and convert u8 to u16 then subtract 128 to convert to s16?
I am trying to read an avi file into this VI. The VIs purpose is to build a 2D array from the avi. Any suggestions on where I am going wrong?
(2,827 Views)
I'm not entirely sure what what you application is doing. Are you taking each frame from the avi and then doing some processing on it? Why exactly do you want to turn it into a 2D array?
Regards
Jon B
NIUK
(2,804 Views)
Hi John,
Yes, I am post processing a frame. Only one frame exists on the avi file. But I want to read an avi file into the VI, convert the avi into a matrix and convert the data type from unsigned 8 bit to signed 16 bit. The outcome will eventually be a 3D image.
(2,799 Views)
If you really want to handle the Image as an array then you can use the IMAQ ImagetoArray.vi and then just use a To Word Integer function from the numeric>>conversion pallet, to change the data type.
Regards
Jon B
NIUK
(2,789 Views)
