Read and edit a data file
Greetings all. I really need some help with this as I am under a big time constraint. I have not had much experience with file handling. I need to be able to manipulate a data file in the following ways. Display a matrix of model numbers along with their associated parameters. There will be 4-6 parameters for each, consisting of both numeric and text data. I also need to be able to edit any of the models listed, delete any model, add a model, etc... It will then have to be saved back to the original data file. I know I can create the original file with Notepad, tab delimited. Can someone please help me with this? I am not sure how to approach it. The user can not be prompted for the file or path. I can provide the proper path for any VI that is provided. Please help...
example of data file
Model               ratio                excitation                resistance                boost
model1             16                     22                           142                          no
model2             1x/8x                 16                           98                            yes
etc..
etc..
(4,471 Views)
hello,
I've made a quick example just to give you a boost. I hope that this will give the initial start to help you creating the application.
I was developed on Labview 8.2
Software developer
www.mcm-electronics.com
PORTUGAL
(4,449 Views)
You don't mentions which version of LabVIEW that you are using. Here's something simple in 7.1 that uses the Read/Write Spreadsheet File modified for string data. LabVIEW 8.2 functions are polymorphic and you don't need to edit them to read strings. The data is just displayed in a table. The read writes to a local variable of the table so that it can be a control that can be changed by the user and then saved.
(4,445 Views)
Thank you both for your help so far. Jorge... any chance you could post this vi in version 7.1? It is all I have just now. We do have version 8.01 but I have to wait another week or so before I can install it. Even still, I would not be able to look at version 8.2. I would like to be able to view both examples that have been posted so that I can learn as much as possible. If it is not possible to post the vi in V7.1, any chance of posting images of each frame of the vi??
Thanks again.
(4,430 Views)
Sorry!
Using Labview 8.2 I only can save to 8.0.
To do something in 7.1 I should have a Labview 7.1 installed on my PC. And I can't do that. But what I've done it's  very similiar to what the other example. I only had created the delete button.
Software developer
PORTUGAL
(4,426 Views)
Jorge... Can I ask you one more favor please? Would you mind uploading the vi you created as a version 8.0 vi? I now have 8.0 on my system. I used the other vi to get an idea on how to do what I need, but when I tried to add the delete function I keep messing it up. I also want to try to add an insert function also.
Thanks... I sincerely appreciate it.
Frank
(4,403 Views)
ok,
In attach follows the 8.0 version. I think that not all the things are going to work
Software developer
PORTUGAL
(4,389 Views)
