Read a virtual CAN-Channel created by Kvaser CanKing in LabVIEW
Hello everyone,
I guess the problem I'm about to post here is pretty unusual . Because I didn't find anything close to the subject on the forum.
So here is the thing: I have a program called catoolRT 19.9 that calculates in a very precized way some data that I need. In discussion with the company that made this software I have been informed that a "direct-communication" between catoolRT 19.9 and LabVIEW  isn't possible. However, it's possible to send the data generated by catoolRT 19.9 to another Software called Kvaser CanKing
Kvaser CanKing is able to generate a virtual CAN-Channel which maybe could be called by LabVIEW to get the data generated by catoolRT 19.9
So my question is: how to read this virtual CAN-Channel in LabVIEW?
I really apreciate your help!
best regards
Ezzow
(2,277 Views)
Accepted by topic author Ezzow
I think I'm now able to get my virtual can channel data using the KvaserExample.vi
Now I would like to convert the CAN-Data that I have using a specific DBC-file.
is there any VI's like the one in the XNET palet that convert CAN-Data after attaching a DBC-file ?
best regards
Ezzow
(2,254 Views)
In case someone is looking for an answer: http://hooovahh.blogspot.com/2017/05/can-part-5-signal-api.html
Just make sure to enter the right signal names in here:
Many thanks @Hooovahh for the amazing blog!
(2,205 Views)
see attached code to my solution. All the libraries you'll need are linked in Hooovahh's blog:
http://hooovahh.blogspot.com/2017/03/can-blog-introduction-and-downloads.html
(2,110 Views)
