Read a counter with string data from CompatLogix 5370
Hi to everyone, I'm reading a Boolean data from CompactLogix 5370 with Labview 2016 using like chain the OPC Server of Labview, with the boolean data I'm haven't problem, just when I try read the String data I have problems, I converted the data of the counter in the studio5000 using the datablock DTOS of the ASCII conversion adjust the DINT to String. but continue with the same problem!
any idea about this?
I attached two pictures with the data.
Regards!
(2,408 Views)
Hello Eduardo,
Based on the error message from the screenshot you just sent, I think you need to first investigate what are the valid data types for "CONTADOR_STRING".
It says it is an address, so I think it may accept a numeric data type, instead of a string.
(2,359 Views)
Thanks ARVega, let me looking for.
Regards
(2,354 Views)
