Read a character from a file
Hi guys
I have a .txt file. In that file the data are stored like "$341ACF12341ACF12341ACF12341ACF12341" now I want to read the next 128 bytes after that "$" character ??
How to execute that??
Thanks in advance
Niladri
Message 1 of 12
(3,738 Views)
"Read Text File". Then look at the "Search/Split String" and "String Subset" VIs in the String palette to slice and dice it.
Message 2 of 12
(3,734 Views)
hi Newbee_3,
                             Hope this attached image will help you. If not than let me know.
Ranjeet
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 12
(3,731 Views)
Actually my file contains many $ character as the file gets updated so does the no of "$" character and their is no way to tell how many "$" is their only that each $ character is separated by 127 bytes. That is my main requirement
Sorry for giving wrong information at the first place
Thanks in advance
Niladri
Message 4 of 12
(3,725 Views)
Then use an offset to read the latest one... Use kind of FOR loop.
--Ranjeet
Message 5 of 12
(3,717 Views)
Can you please elaborate it?
Thanks in advance
Niladri
Message 6 of 12
(3,713 Views)
what i mean to say that as soon as you read the data & appends on txt file
1. Convert the data into string.
2. Inside for loop read the substring with number of char as 120 & offset as i(Current itearation of FOR loop) * 120.
3. Read the 120 char or bytes & play with it..
See i haven't saw your code so i can give you only suggestion, Implementing & placement of components depends on your application.
                                                 If you are not still satisfied than let me know, i will elobrate again with one illustrative image
--Ranjeet
Message 7 of 12
(3,710 Views)
Here, assuming you are reading the entire file rather than line by line:
Message 8 of 12
(3,708 Views)
You can read the text file to read the data as a string and use $ as a delimiter in Convert spreadsheet string to array.
Message 9 of 12
(3,705 Views)
Accepted by topic author Newbee_3
Or, use Read From Spreadsheet File.vi with $ as the delimiter.
Lynn
Message 10 of 12
(3,682 Views)
