Read/Write data to/from compact fieldpoint using PDA.
Anyone out there knowing how to read an analog input from compact fieldpoint, using wifi, to my PDA (ipaq 5450)?
And how do I write data from a potmeter in an "vi" on my PDA to a fieldpoint analog output?
Best regards
Sjur
(3,453 Views)
If datasocket functions were available on the PDA it would be trivial, but they are not. You can write a pair of vis that set up a TCP connection between the CFP and the PDA using the TCP communication functions. Alternatively, you can use the "Call by Reference" function on the PDA to run a remote vi that will read or write a value. That vi can reside on the Fielpoint device or on another computer.
(3,453 Views)
Thanks Richard, I will try it out.
Sjur
(3,453 Views)
