取消
显示结果
搜索替代
您的意思是:
Read/Record in Access by Labview
已解决!
转到解答
Hi for all!
I'm new in Labview and I'm trying to make a program that records date/hours in MS Access. I started this project using Active X, but I'm half lost. I know that you have discussion on the same subject, but I use LabVIEW 8.0 and I can not open.
I open the database and i read what is in his columns, but I would like to add data (date / time) in a box (column) specifies (called "Registro") preferably record on the line where the "Codigo1" beat with the signal that entered.
The scheme is as follows: Get a sign in the form string in Labview, which instantly records the date / time that the signal was detected in a file .mdb, which in turn writes the same line where the string corresponds with the signal, in column "Registro".
Can someone help me?
Patrícia
0 项奖励
1 条消息(共 5 条)
3,853 次查看
Rule 1: DO NOT UPLOAD BITMAPS TO THE FORUMS.
Rule 2: DO NOT CHANGE THE EXTENSIONS OF BITMAPS TO ".jpg", ".gif", OR ANYTHING ELSE TO GET AROUND THE BAN. THE BAN IS THERE FOR A REASON!!!
There, now, to your issue. You haven't shown any code. Are you using the Database Toolkit?
2 条消息(共 5 条)
3,845 次查看
Sorry, i did not know.
I don't use, but I follow some examples that are in that forum, which is: Connectivity>> Active X
0 项奖励
3 条消息(共 5 条)
3,778 次查看
解答
已被主题作者 Patrícia 接受
You should really forget about any examples you found that use ActiveX and Access. This method is slow and requires Access to be installed. Either buy the database toolkit or download LabSQL. Both are based on ADO are much simpler (imho) to use than ActiveX. The NI toolkit is especially easy to use for those not familiar with databases and SQL.
4 条消息(共 5 条)
3,771 次查看
Thank you very much!
0 项奖励
5 条消息(共 5 条)
3,700 次查看
