Read LEDs of a system under test?
I have a system (with real LEDs, i.e. not inside labview) that that can have the following color states for LEDs:
Red, green, yellow and none.
it should also be possible to detect a blink frequency up to 2 Hz.
Is there any equimpent for this? I know it can be done with IMAQ and cameras but is there any other measurement way? With opto components?
/Regards
Message 1 of 8
(3,840 Views)
I would have measured the LED voltage, since it will be different for different colors. Correct me if I'm wrong though.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 2 of 8
(3,837 Views)
I would agree that simply measuring the voltage should be an easy way to determine if the LED is on and/or blinking. Your frequency of blinking is quite low, so you won't need high-speed data acquisition. As for the varying voltages, that should not be the case. It's not clear from your post whether you're dealing with different LEDs, or multi-color LEDs. However, even with multi-colored LEDs, they have multiple leads to activate the different colors, not different voltages.
Message 3 of 8
(3,822 Views)
A quick Google search turned up this video that shows LED testing using opto components.
Bookmarking this for my own possible use.
http://www.youtube.com/watch?v=BMfl2mrPI2s
Product web site: http://www.feasa.ie/
Message 4 of 8
(3,817 Views)
Message 5 of 8
(3,812 Views)
LEDs themselves can be used as color-selective photodiodes.  If you can get the same type of LED used in the device, couple it optically to the LED being tested, connect it as two or three photodiodes*, then connect the outputs of the photodiodes to an analog input device.  Measuring the voltages out of the photodiodes should get you to the information you want.
* Two if the device has two diodes and gets three colors by having both on at the same time, or three if it has three diodes.
Lynn
Message 6 of 8
(3,799 Views)
Here comes some late answers:
1. The LEDs are all built in into the system and therefore not possible/resonable to connect probes for voltage measurement.
2. Its multi colored LEDs attached on the PCB (i.e. really small connections)  with green, red and yellow (all max 2 Hz).
Also the system contains quite a few LEDs of this kind (say about 50) so i am leaning towards an camera solution where all LEDs can be read. Can it be done with a webcam?
Any inputs there?
Message 7 of 8
(3,763 Views)
