'Read JPEG File.vi' does not seem to work on PXI with real-time OS
I am trying to read a jpeg file on a PXI system with LabVIEW real-time on it. To test I created a very simple VI (attached) with only 4 objects: 'Path' --> 'Read JPEG File.vi' --> 'Draw Flattened Pixmap.vi' --> 'Picture'.
This VI works fine on my Windows XP host machine, but it does not work on the PXI system. The error code 1 occurs in 'Read JPEG File.vi'.
The jpeg picture is in the same directory as the VI. I don't think I got the path or filename wrong because if I change the file or path name I get another error: 7: 'File/Directory Info in Check Path.vi->Read JPEG File.vi->test.vi'.
Maybe reading jpeg files is not supported on realtime systems? I could not find anything about it. Sol
utions or workarounds are of course welcome!
(3,859 Views)
'Read JPEG File.vi' is not supported on LabVIEW RT. I believe it has to do with special functions or libraries need to be called due to the JPEG image type. Instead you can use a Bitmap and the 'Read BMP File.vi', which I believe is completely implemented in G code.
Keep in mind that the RT System doesn't really have a front panel and that the front panel is only 'available' when LabVIEW is connected to the target such as being targeted or having a remote panel to it. Generally, a deployed RT system doesn't have a UI and just communicates to a Host VI which acts as the UI. Having said that, the BMP file worked when I tested.
JR A.
(3,859 Views)
Ok. Thanks for the clear answer. I will try to find something that first converts the JPEG images to BMP images before they are uploaded to the RT system.
(3,859 Views)
Having the same problem here.
I want to upload a jpg per FTP from my webcam to my fieldpoint system an display the picture in a remote panel. But as read jpg is not supported by RealTime OS it is not working so far.
Anyone got some ideas or a workaround for that?
(3,345 Views)
TOBBR,
As mentioned by JR A. above, the RT environment does not support opening JPEG files.  I tried an alternate solution using the VIs from the IMAQ driver, and had no success with that either.
If possible, I would recommend converting your webcam image to a BMP on your host before FTPing it over to your target.
(3,328 Views)
