Read Data through RS232 4 Serial port and VISA parallely
@Vr0 wrote:
@RTSLVU Hi, I'm looking for information to Yokogawa wattmeter and if I well understand maybe you use the same as I. It's an old WT230 and I have problem not to send request but to keep back query. Can you contact me about this ? Thank you to help me to solve my problem. You can contact me by MP. Rgs Vr0.
Some reason I can't message you but please explain the issue you are having with the WT-230 and attach your code in LabVIEW 2023 or older.
=== Engineer Ambiguously ===
Message 21 of 23
(259 Views)
Hi, I try to use YKWT200 Application Example1.vi from a zyp file called ykwt200.zip. I have change the com port with the right port number but I don't know where I have to specify wattmetter type (WT230) and if I have to specify anithyg else. Thank you for your help and sorry cause I'm beginner in labview.
VrO
Message 22 of 23
(228 Views)
VrO
TBH: I don't have as lot of experience with Yokogawa's WT-Viewer software.
You should contact Yokogawa for questions on their software
Message 23 of 23
(215 Views)
