Read Data With 2 Pins Using Arduino One
Please, look at this photo I provided. I am trying to read data that is coming from pin 12 and 13 but I get nothing. Maybe something is not set up right. Can someone please help me?
Thank you!
(4,536 Views)
Use block diagram cleanup so it is easier to see what wires go where and in what order the subVI's execute.
Do you get any error messages?
You have the two pins set to input, yet you try to do a Digital Write on them.  Why?
For the digital Read, I don't see where you tell it what pins to read on those subVI's.
Also, your VISA resource is an empty constant.  Shouldn't you be telling it what serial resource the Arduino is connected to?
(4,494 Views)
Hello Friend,
You can't write anything to the pins configured as INPUT,
Change the configuration to OUTPUT and give 0 OR 1 to Digital Write function and see the magic.
Regards
Love Diwan
KUDO is the best way to say thanks.....! Smiley Very Happy
(4,486 Views)
You can not read a pin configured as an output and you can not write to a pin that is configured as an input.
You configure pins as input to read them.
You configure pins as output to write to them.
=== Engineer Ambiguously ===
(4,477 Views)
Alright. Thanks.
(4,427 Views)
