Read Current Buffer Value DAQmx
Is there a way, using DAQmx to read the current buffer value that is being written? I need to plot the buffer output in relation to a process measurement.
S
(3,014 Views)
Hi S
Could you describe what you are doing in a bit more detail. What form of acquisition are you using? analog I/O, digital I/O or counters. Are you looking to compare the buffer size with your measurement?
Regards
Yatin
(2,984 Views)
Hi Yatin,
Thanks for the response, I have sorted the problem.
I was tring to plot the response of a machine to it's input signal. I am now simply using the generated sinewave that is being written to the buffer and plotting against actual displacement (from a linear encoder). I plot the buffer values first and then overlay the feedback data.
s
(2,981 Views)
nice one,
thanks for letting me know
Yatin
(2,976 Views)
