Read CPU temperature of Desktop PC running LabVIEW Real-Time
Is it possilbe to read the CPU temperature of a Desktop PC running LabVIEW Real-Time? I found an older example that allows to read the temperature of PXI systems (http://www.ni.com/example/29538/en/). Is there a possibility for Desktop Real-Time Machines as well?
Steffen
(3,664 Views)
Hi this is heavily dependent from your specific Hardware. Which PC or more specific which main board do you use?
I found several examples in the NI forum that try to access the CPU data.
I’m using a Dell machine and both temperature VI’s are not working for me.
Hope you have more luck.
(3,626 Views)
