Read 3 serial port from Arduino in labview
i have 3 RFID reader that each one of them joined to one arduino and receive data from 20 RFID card that they set from number 01 to number 20. so i need to see and store each card when it read by each RFID.
i need to have led turn on and remind on in labview when each card read from any RFID.
and i need to save data in a excel file like ( time and  date each card read and number of card ). each card read two time start of job and end of job. so i can see how much time took for that job to finished.
Message 11 of 16
(1,414 Views)
can you fix just part of my code in way you think and then i do all like that?
also that high resolution time is not needed. i deleted them.
Message 12 of 16
(1,410 Views)
Hi amkamyab,
So you need a datastructure able to store 60 entries. (Use an array!)
So you need to store for those 60 entries just 2 values: use a 2D array of 60 rows and 2 columns…
Suggestion:
- start from scratch.
- At first create a VI just for the purpose of a stable communication with your Arduino. Have it receive the slot numbers in a error-proof way.
- Once you got that you create another VI able to store those 60×2 timestamps and calculate the time differences…
- At last you implement the data saving to CSV files…
Message 13 of 16
(1,409 Views)
Hello everyone
as i put in fallow, i have a program that will read number 1 and 6 and 16 and record them in a excel file. but i don't know why sometimes for example real data is 16 and labview record it as 1 and 6. i don't know what is wrong
Message 14 of 16
(1,416 Views)
Move conf VISA from loop
And you really get string "16"? May be you receive only one byte
Message 15 of 16
(1,403 Views)
Hi amkamyab,
Wrong is to create a new thread for (more or less) the same problem - without providing needed background information. That's why I moved your message!
It's also wrong to use BytesAtPort as I told you before!
Is it still the same sender routine on your Arduino?
Then why do you still use FractStringToNum?
(You also didn't change those ArrayToCluster/Unbundle operations. You still collect TRUE values in evergrowing arrays…)
Message 16 of 16
(1,400 Views)
