11-30-2017 02:07 AM
Hello, I have a same problem like you. You already solve your concern but I am struggling with this problem. I am using usb 6001 and bipolar stepper motor. Can you share the PWM VI example? I am wondering usb 6001 can use for PWM as well.
11-30-2017
02:17 AM
- last edited on
09-25-2025
09:03 PM
by
Content Cleaner
Hi Kevin,
why did you hijack an old, but totally unrelated thread?
You are using different hardware…
- Did you read the spec sheet of the USB6001? It only supports "static DIO": no waveform generation on DO lines…
- LabVIEW/DAQmx comes with a huge library of example VIs: did you search for suitable examples in the example finder?
