Re-run Event Structure after controller message output
Simply put, I have a program that runs a voice coil through a controller.  I press the "Begin Fretting" button and the program runs the specifiec number of cycles and then motion stops (program still running).  The controller puts out the message "Fretting Complete" at the conclusion of motion.  Is there a way to have the controller message output (could be anything doesn't have to say "Fretting Complete", re-trigger my "Begin Fretting" Event so it will continuously repeat the cycle sequence until I press the stop button?  Here's the code I came up with attached.. (no sub vi's attached so it won't actually run).  The Begin Fretting event is on the right...  Controller message right next to it to the left. Hopefully this is a pretty simple task.  Tried searching, no luck.
Thanks!
Gus  (novice user as you can probably tell)
(2,517 Views)
you need to make the message change in the 'event_on Message.vi'...which you have should included
(2,512 Views)
These should be all the VI's I use.  For some reason my project never works when I just transfer it from one computer to another so posting the project I'd assume would fail as well.  These are the 4 total VI's I use however...
(2,509 Views)
