04-16-2008 06:22 AM
04-17-2008 11:11 AM
Hello Shimon,
To access the LAN settings:
My Computer>> Properties>> Hardware>> Device Manager>> Network Adapters
Expand the Network adapters. Then right click on the appropriate adapter,and select Properties.
Once at the Properties of the adapter you will see several different tabs (General, Driver, Advanced, Details, etc...). Select the Advanced Tab. You can alter the baud and duplex mode settings from the speed & duplex. If you want to uninstall the network adapter, then you will need to go to the Driver Tab. Once at the Driver Tab you will have the ability to update the driver or uninstall. I would suggest you try to update the driver prior to completely uninstalling and reinstalling it. If you elect to uninstall
be sure to note the name of the network adapter. You can then redownload the driver from the internet.
I have follow-up question, why are you wanting to uninstall and reinstall the LAN driver, and why do you want to alter the baud rate?
04-17-2008 01:02 PM
Hi Rayen,
P.S: The mentioned HUB or Ethernet Switch is connected with a Crossed Cable to the PXI unit, and from another port its connected to the HOST PC.
Shimon.
04-18-2008 10:20 AM
