Re-initializing my array with reset button
Hey cbutcher !
Sorry to bother you once again. Hope youre doing fine.
Im stuck with one issue now. I have a 16-bit data and I wish to read each bit individually. This is because each bit represent a particular information. (E.g. It represents whether the warning is on for each component, if it is on, I would read a "1", if it is off " I would read a "0").
But I am unable to read each individual bit.
Your help would be greatly appreciated.
Jarrold
Message 91 of 93
(818 Views)
Assuming what you have is a U16, you can simply use the Number to Boolean Array primitive to get a boolean array 🙂
GCentral
Message 92 of 93
(814 Views)
Yeah, i got my project to work perfectly cbutcher !
Now, I got this problem and I am not very sure where went wrong.
Apparently, after i generate my report, the font size doesn't seem to be right. I tried setting my template font size already but it still isn't working. Do you have any idea?
Attached is an image of the generated report for you to have a better idea of what I am talking about. Observed that fonts are so much smaller than "Load (%)" which shouldn't be case. I want them all to be the same. 😞
Message 93 of 93
(804 Views)
