Re-initialize to default while running
I want to re-initialize all front panel objects to their default values while the vi is running.  I am using this to clear displays, empty arrays, etc. before the next time the vi runs.  I know how to do this object-by-object.  I would like to do it in one swell foop.  The vi is all by itself (i.e.: not called by another).
Roy
(6,582 Views)
Actually this is fairly simple. You just have to open a reference to the front panel and then use an invoke node with the methode "Reinitialize All to Default".
I've included a short example here.
     Rob
(6,578 Views)
