Re: datasocket api documentation
good day sirs,
how is it today, 12 years later ?
I'm facing a similar problem
greetings Max
(2,511 Views)
Hi Max,
What exactly is your problem? How "similar" is it to the old problem?
(2,506 Views)
Hi, thx for your reply.
I try to use a http api command on Ubuntu 20.04 with Labview 2021.
using:
-LABVIEWHTTPClient:GET
-commandline VI with wget
-commandline VI with curl
are not working.
just right now we tested REDHAT with LV2019 and wget was working there.
seems like the combination of Ubuntu 20.04 with Labview 2021 is failing some how
greetings Max
(2,491 Views)
Hi Max,
so you are not using DataSockets as was requested in the old thread…
using:
What means "are not working"?
Errors? LabVIEW crash? Computer crash? Computer going up in flames? (Apparently no BSOD on Linux… :))
(2,467 Views)
So basically wget and curl are not working? What has that to do with LabVIEW?
I would guess you have a fundamental problem with your network configuration and/or access rights.
Whatever it is, it has ABSOLUTELY nothing to do with the thread you tacked your message to.
Rolf Kalbermatter  My Blog
(2,399 Views)
it is working now:
there are several locations in Ubuntu where you have to setup the proxy !
@Knight of NI
in the Linux terminal curl was working
but the same command didn't when Labview used the commandline tool
this was just a step in problem solving, now I use the getHTTP vi, works fine
thx 4 ur help !
(2,376 Views)
