Re: convert string to number
hello to everyone,
I would like to know if you can help me I am reading some data from several sensors by the serial port and I need to put them in an array and then separate them by arrays in columns data by data and then click each position of the array by a value and add that is in order to replace an equation.
I mean I have y= 0,0034*(dato1)+0,975*(dato2)+0,4521*(dato3)+0,1234*(dato4)+1.935*(dato5)
where the data are the values that come in through the
and also I need that when I calculate each data of and save it in a matrix
I hope you can please help me because it is a matter of passing a subject.
thank you
Translated with www.DeepL.com/Translator (free version)
(1,347 Views)
  • You get better help if you attach a VI instead of a picture.
  • How does the received string look like?
  • You cannot do math on string, so you need a numeric datatype.
  • Once you have your array of [dato1..5], multiply it with an array constant of [0.0034, 0.975, etc] then take the sum to get y.
  • You don't want a "matrix" unless you do linear algebra. Just use a 2D array.
(1,315 Views)
