Re: convert hex string to number
Good Afternoon;
I am trying to do the same thing.  I am reading 8 bytes of data from a modbus gateway.
I grab the substring that I am interested in....if I set the display to normal the reading is non printable.....set to hex display the reading is 3098 should be decimal 12440 I believe?
This feels like I am close but not quite.............
(4,790 Views)
@mned wrote:
Good Afternoon;
If you have the section of the string that is your data, use Unflatten From String to convert to your number (either I16 or U16).  I say to use the Unflatten instead of the Type Cast since you can specify Big Endian or LIttle Endian.
(4,771 Views)
@mned wrote:
Good Afternoon;
You do have it.
Decimal 12440, whether it is U16 or I 16, will directly typecast to hex 3098.
If you don't think you have it, then post a VI that shows the data you have saved as default in a control and the way you are trying to manipulate. it.
(4,764 Views)
Here it is, String2 and substring are set to hex display.
String2 is read directly from a device.
The payload of the string is 08B6.
I need to convert this to decimal......should be 2230.
the 2230 / 100 = the position that I sent the actuator to.......22.3mm.
I can not get the conversion......
(4,738 Views)
I know my last post was with a different value than the first.....I have 2 different axis
(4,735 Views)
Accepted by crossrulz
Did you even try our suggestions (Type Cast or Unflatten From String)?
(4,732 Views)
THANK YOU!!!!!!!
(4,727 Views)
