Re: Write and read serial port simultaneously
how to read the same data that is written to the COMport.
(2,076 Views)
Please open a new thread. Probably your question has nothing to do with this old post.
What you mean exactly? Please give details: do you want to read with what: another program? another computer? ...?
Paolo
(2,069 Views)
How to write data to the COM port? And also I want to read the same data from it.(which I write to the COM port)
(2,064 Views)
What's the point in doing this? This is nearly nonsensical. You already know what you wrote.
If you insist, you can put a loopback on the serial connector. If the serial port is a two wire RS-485, you even don't need the loopback.
Paolo
(2,052 Views)
As already stated, if using RS232 or RS422, you need a loopback on your port.  For RS323, this means you wire pin 2 to pin 3.  What I typically do for testing a serial port is to use 2 ports with a crossover cable between them.  Then when I write on one port, I can read on the other.
(1,991 Views)
Or you can use a null modem emulator, such as com0com
(1,958 Views)
Start here:
How to Perform a Serial Loopback Test
Also watch this video before you begin ANY serial communications programming:
VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(1,952 Views)
