Re: Watlow F4 Controller with LabView
Hi All,
I'm trying to read the temp on the F4 using labview, with the controller connected through the internet. I can see the controller using the “PING” command on a cmd window, but I cannot see it in the MAX .
Thanks, Erez
Message 1 of 15
(7,526 Views)
Hi Erez,
why do you expect to see you F4 in MAX?
MAX is a tool from NI to configure all hardware from NI.
MAX is not intended to be used for 3rd party hardware…
Message 2 of 15
(7,481 Views)
Can you please elaborate a little bit on your setup? I have worked with F4 controllers in LabVIEW, but I'm not sure about the part that you mentioned you are connected through internet and the pings. These controllers have a Modbus port. I use an ICS Electronics adapter GPIB to Modbus adapter similar to the following one: http://www.icselect.com/gpib_modbus-4899A.html
Then I use a GPIB to USB adapter from NI similar to this one: https://www.ni.com/en-us/shop/model/gpib-usb-hs.html
With this setup I can go to MAX and scan for GPIB instruments connected to the adapter and that's how I get a VISA address for the controller. My VIs can then use that VISA address to talk to it.
Certified LabVIEW Architect (CLA), LabVIEW 2015.
Message 3 of 15
(7,477 Views)
Dear All,
Thanks for the help
All I want to do is to read the FT4 current temperature.
My FT4 is connected to the internet (this is why I mentioned the “ping”)
I was hoping that I can talk to it using “Visa” (just like Tektronix scope or Keithley data logger)
So my set up: I have the FT4 connected to the net (IP 10.0.202.25) and my host computer in on the same subnet.
Thanks, Erez
Message 4 of 15
(7,464 Views)
can you able to communicate with device using Assigned IP using LabVIEW (if so no point in expecting to display in NI MAX)
Message 5 of 15
(7,458 Views)
no
Trying to open Visa result in an error
Message 6 of 15
(7,455 Views)
BTW, I’ve downloaded a software from Watlow that can communicate with the F4T using the net
thanks, Erez
Message 7 of 15
(7,450 Views)
Are you using Serial port or Ethernet port if ethernet port you can use TCP/IP
There may be LabVIEW Drivers available for your specific device you can browse and download
There are other softwares available to communicate with a device (Putty, Tera Term), which will clarify the problem whether it is a problem with hardware or the LabVIEW which is not detecting.
Message 8 of 15
(7,435 Views)
I’m using the Ethernet port (BTW, I thought that Visa include TCP/IP). I’ve already downloaded a different software that communicate great with the FT4.
Best, Erez
Message 9 of 15
(7,432 Views)
Can you share your actual code?
Message 10 of 15
(7,426 Views)
