Re: Using Simulate Arbitrary Signal
Hi duyngoc,
please help me
Until now you didn't attach any VI.
How should we help to improve your code when you hesitate to attach that code?
(I prefer LV2017…)
Message 11 of 21
(2,003 Views)
Dear Sir
I am sorry for that. As I attached the figure, I just think that it is very simple so I did not attach the VI program here
Below is the VI program and the .lvm data as my excitation signal. Please help me or give me suggestion
Thank you very much
Message 12 of 21
(2,000 Views)
Hi duyngoc,
your VI already outputs the very same signal each 50ms to the graph.
What else do you need?
When you want to see it on your frontpanel you could try this:
Note: I replaced the graph by a chart…
Message 13 of 21
(1,997 Views)
Thank you very much
But which option did you choose in the "Configure Convert from Dynamic Data" block? I chose "1D array of scalars-automatic" but I did not get the result I need. Could u kindly attach the code here? I use LV2014 version now
Message 14 of 21
(1,984 Views)
After adding "Configure Convert from Dynamic Data" block and Write Measurement Data Express VI, I checked the data obtain for each iteration. I realized that the data I got is from 0 second to 5 second for each iteration. But the one I want is time is continuously go as 0 second to infinity and only Y value can be repeatedly obtained from the original data. Is there any method to do this?
Message 15 of 21
(1,971 Views)
Hi duyngoc,
Yes, the data in your file lasts for 5s.
This is what my last snippet does: repeat those Y data obtained from original data…
Message 16 of 21
(1,967 Views)
How can I repeat only Y column data obtained from my original data?
Message 17 of 21
(1,961 Views)
Hi duyngoc,
use a loop as shown above…
Message 18 of 21
(1,956 Views)
I used the loop as shown in the above but I dont know how to set the condition in the Read Measurement Data block and Configure Convert from Dynamic data block. Could you let me know how to choose the option in there?
Message 19 of 21
(1,950 Views)
Hi duyngoc,
The same as you used before to read just that signal…
Convert DDT to 1D array of scalars.
Message 20 of 21
(1,946 Views)
