Re: Re : how to run an USB-TC?
hi sir,
i do the programe for USB-TC, its run in my computer and reading are shown. when i try to run in my target system, the reading are didn't shown. i install Labview RUN-Time Engine in Target system. In target system i am execute the exe file.
(3,802 Views)
Hi ponkumar,
did you install other needed drivers like DAQmx?
Did you include any definitions like DAQmx tasks, when you defined them in MAX?
Do you get any error messages and did you read up their explanations?
(3,798 Views)
hello sir,
yes, i install NI-MAX software.
No, i didn't define.
No, i didn't get any error message.
(3,770 Views)
Hi ponkumar,
So do you get readings, but have problems to display them?
Or don't you get readings at all? If so: why don't you get error messages then?
Did you implement some error handling including display/logging of error messages?
Can you show your VI(s)?
(3,765 Views)
If this is a USB-TC from Measurement Computing, you need to install its drivers and InstaCal software on the target computer just like you did on the development one. Download the MCC DAQ CD from https://www.mccdaq.com/Software-Downloads and install it on the target computer.
(3,754 Views)
