07-01-2021 04:36 AM
Hi everyone I am working on this bloc diagram (attached file) and I would like to display the graph current vs time during my measurement. The graph votage vs time is display but not current vs time .I would like to observe both on two different graphs current vs time and voltage vs time .Please anymone can add the appropriate modification to help me. I am in chemestry backgroud.
Thank you very much
07-01-2021 07:09 AM - edited 07-01-2021 07:18 AM
Hi Stephkd,
You really need to work a lot more on this block diagram!
Why do you need so many local variables? Use wires instead!!!
Why do you need to copy data from a control terminal into a local variable to the very same control???
All that tells us you REALLY should take the beginner courses offered in the "Training resources" at the top of the LabVIEW board. Take a close look at the topics about "THINK DATAFLOW!"…
(Like in State "ConfA" there is NO local variable needed at all!)
So you already know how to plot voltage over time: just do the same for current over time!
Btw. you don't plot your data "vs time" the way you are using simple chart! You just plot data over "number of measurement"…
