Re: NI 9263 dc voltage output
how can i send the signal to the channel that i chose and see that in a oscilloscope?
(3,331 Views)
Hi kilkis,
use DAQmx functions to set an AO voltage.
Then use (real copper) wires to connect your NI9263 with your scope.
(3,324 Views)
my output is digital how can i produce and send the digital pulse(constant) to a channel of my card(i have NI-9402
(3,322 Views)
Hi kilkis,
use DAQmx functions!
Hint: LabVIEW comes with a huge example library…
(3,319 Views)
Hello i send a PWM signal to a digital channel( so i use 1 sample on the signal simulation tab ) I want my duty cycle to start from 0 to 100% with a  step controled by me,increasing it every 100ms (RATE in circuit). I make a while loop to add Function but the value doesn't reach duty cycle. How can i do this?
(3,302 Views)
(3,300 Views)
Hi cortex,
How can i do this?
Create a VI working exactly on your requirements…
You create a PWM with just one sample? How will that work?
Which circuit are you talking about? Is there  a PCB connected?
On your image:
- Ever heard about creating screenshots without using a camera or mobile?
- Cleaning up the block diagram before making screenshots usually increases readability of the code.
- hiding settings in ExpressVIs doesn't help to increase readability
- attaching an image of a VI doesn't help us to debug your VI
Conclusion: Attach your VI!
Edit:
I moved your questions into your own thread. And I merged your double post into this one too.
Please don't hijack old, unrelated threads and keep your questions in one place!
(3,299 Views)
