Re: Moving Average Filter
For interpolate in that document they gave as linear interpolate. But in my labview i dont find the in built linear interpolate.
Message 11 of 18
(1,267 Views)
Hi suryas,
If you give your ideas i will on m y own.
The forum works the other way around: You show your VI, you explain the problems you have with your VI and you ask for specific help on your specific VI…
Until now you haven't shown any work of your own!
Linear Interpolate: Interpolate1DArray or "Interpolate 1D.vi". Use Quickdrop and type "interpolate"…
Message 12 of 18
(1,264 Views)
This is the VI i tried with your help. First i tried to do the VI wher i doont know how to design MA filter and how to add samples. I have done this. Is there any modifications i have to do to make it perfect.
Message 13 of 18
(1,256 Views)
Hi suryas,
Unfortunately I'm stuck at LV2014 right now…
Message 14 of 18
(1,251 Views)
1.  Put in a From DDT immediately after the Delay Values to change it to a single waveform.  You will need to add in a Get Waveform Components to make it work, but everything else will make more sense.
2. Your Standard Deviation PtByPt needs to be inside of a FOR loop.
Message 15 of 18
(1,243 Views)
Okay No problem. thanks alot for your help
Message 16 of 18
(1,241 Views)
I have made changes of these two points in my VI.
Is there any other corrections i have to make?
Surya S
Message 17 of 18
(1,236 Views)
By using this VI I have to get the confidence interval for frequency. But the output am getting for Amplitude?
Message 18 of 18
(1,229 Views)
