Re: I am a student and I am looking for a driver for the Instech Pump P720.
Hi, I also need to make thermsitor measurement. Could you successfully use NI 9205 for this purpose? If yes, then how?
(2,354 Views)
Hi arihant,
why do you need to hijack an old thread which wa sasking for a pump driver?
Do you have a (electric) schematic of your thermistor? Did you read Wikipedia about those sensors?
As your NI9205 can only meaasure voltages I suggest to create a voltage divider from your thermistor with an additional resistor. Then you can easily measure the voltage drop across the thermistor and calculate the temperature from this…
(2,345 Views)
