Re: How to generate UDP traffic
Hi !
I have a similar issue with communication with a piece of hardware.
The problem is that it seems that my message is mixing characters and binary. Here is the data I have to send in each UDP packet (all data is send in little endian) :
4 bytes: 53591 (little endian)
2 bytes: 1 (little endian)
21 bytes: a name terminated by a '\0' character
40 bytes: all zeros
I tried to use the flatten to String  VI to translate my data into string but it doesn't work (in the example above, the name is inexistant but I also tried to include some ASCII characters into bytes in the byte array, without success).
I also tried before to convert my whole message into a string of 0&1's and also a translation of the data into a hexadecimal string, and also a translation of the message to ASCII characters, all three trials without success.
Thank you in advance for your help !
(2,915 Views)
Accepted by topic author RomainLegrand
Hi Romain,
when you upload a VI you should also attach any needed subVIs!
THe main problem with your VI are the incorrect datatypes of the numeric constants.
See this example:
The datatype is given by the labels of the constants…
And please don't hijack 10 years old threads. Start your own thread instead…
(2,905 Views)
Thank you a lot, it was indeed the problem.
Sorry about the sub-VIs, I thought that I put the simplified version of my VI on the topic, without all the useless sub VIs.
(2,883 Views)
