Re: Histograms for 1's and 0's
Hi guys, I require some help with my LabView project. As you can see in the VI provided down below, I created an eye diagram. I then converted that eye diagram to a histogram which consisted of all the y values from the eye diagram. The problem I have now is that, I need to create two more histograms one for all the 1's form the eye diagram and the other for all the zeros from the eye diagram. I will then use the data from these histograms to work out the Q value.
If anyone can help me out with this I would really appreciate it. (feel free to edit the file attached with this message thanks)
Haider
(2,069 Views)
Sorry, I don't have the modulation toolkit installed. Can you run the VI to get data into the displays, then make the current value of "eye diagram 1" the default. Turn it into a control (right-click...change to control) and delete the code before it so we have something to work with. Save under a new name and attach it here again.
(2,032 Views)
