Re: File permission error; NI-488: DMA hardware error detected - Solved
Hello sir!
My name is Visoth. I am from Kscc, now i having some problem with my program and i try to do it, but can not. So I need you help me with this problem. How can I do it.
(4,724 Views)
Hi visoth,
no need to hijack old unrelated threads when you have your own problem with your own VI…
Which problem do you have? Is it just the one in the error message?
How can I do it.
Did you read the error message? Didi you debug your VI according to the hints of the error message?
There's a problem with a WritetoSpreadsheetFile function, most probably you don't have permission to access the file/path - as is written.
Did you debug? Which file path is used here? Did you double check the file path? Do you have access rights for that file path?
(4,713 Views)
Hi sir !
I already read that message, and understand about the problem, but I don't know how to fixing it. Smiley SadSmiley Sad\
So I need you help me Please !
(4,688 Views)
Accepted by topic author visoth
Hi visoth,
So I repeat all my questions from above:
As we cannot debug an image you should also think about attaching your VI. (I prefer them suitable for LV2014.)
(4,686 Views)
