Re: Calling LabVIEW DLL from C# with char array
i have doubt how to access the dll generated from labview project, can someone help me with this in steps.
thanks in advance
(1,402 Views)
What do you mean with "access"? Are you looking for the folder where the dll is being built?
(1,326 Views)
What char array is it? What is the function prototype (header file)? What is the meaning of that parameter? Is it meant to be a LabVIEW string in the VI inside the DLL or an array of bytes or something else?
You need to provide a lot more information to allow us to help you. With what you have provided so far all I can say is yes, I'm 99.5% sure that it can be done. How, you ask? Well, I have no idea since I do not know what you exactly try to do. Or more precisely I have half a dozen ideas but I'm not going to explain them all here for two reasons:
1) I have more interesting things to do with my time.
2) It would only confuse you and not help in any way as now you have one problem, but after you read my half dozen possible explanations, you have half a dozen plus one problems. 😁
Rolf Kalbermatter  My Blog
(1,318 Views)
