Re: CHAT
Can Labview application receive 10Gbps data through ethernet in a PC?
(3,064 Views)
The speed will mostly depend on the devices (and their configurations), you will use to ensure that fast communication between your program and the PC.
National Instruments has products such as NI PXIe-1085(12GB/s) with a System Bandwidth up to 12GB/s.
Please go to PXI Advisor and scroll down till High-Slot Count Modules for more information.
Hope this information answers your question.
Greetings and Regards,
James
(3,011 Views)
10 Gbps is a very high rate.
Basically, if the data exchange is possible between your PC and your Ethernet configuration, it will not be a problem to run the application on LabVIEW.
(I have already sent you a link on instruments that would allow you to deal with such high-speed data.)
Therefore, let us please know more about your system communication (Ethernet, PC…)
Or is your problem solved so far?
James
(2,961 Views)
