Re: Beginner at LabView, Load Cell Force Measurement?
sir how to connect the beam type load cell of 1 kg and same that excidion voltage 5V and how to interface the mydaq device plz explain this is my problem
(2,917 Views)
Hi Ragu,
   It depends on type of daq which you are using and also the signal conditioner to amplify te signal from sensor, anyway what type of daq you're using?
Paul robinson
(2,869 Views)
Accepted by topic author ragusakthivel
actually i am using only my daq, it is useful or not , because i am already  cheack the  my daq  reading was not get aqurately so which eqipment is best result output for loadcell (beam type 1kg) measurement using labview .. please explain me sir
(2,861 Views)
The myDAQ has an analog input with a range of +/-10V. That seems to be plenty for your application with a maximum voltage of 5V.
I don't see where you describe the setup or the exact problem you are having. What have you done, what does it do it, and what do you expect?
(2,836 Views)
