Re: Atmega 16 hardware connect to Labview to form a CRO
Thank you!!!
Thanks for your reply and kindly help~~~
Based on your suggestion, I have tried to modify my vi. However, the problems still here....
I have post two video of my vi. design.
For the <waveform Chart.mp4> video, it shows the problems of my design. The wave and the grid line keep moving.....
When I turn the switch to charge the time base of the Chart, the grid size change at the save time....Then how can I achieve the function of setting the Time/Division like a CRO??
For the <waveform Grahp.mp4> video, I have tried to replace the waveform Chart to a waveform Graph. As you can see in the video, is can show the waveform. Although I have tried to adjust the time scale in order to get a better waveform, I still display the wave....
I hope after having a look on the video, the whole picture can be more clear for you, since you do not have my hardware....
 Would you mind to give me a help again? I feel really dazed and confused at this state...><
(2,248 Views)
this is the 3rd double post for this topic, the original one is found here...
Oh, sorry, there is an even older thread for the same topic...
(2,240 Views)
