Raw PCM to WAV
I very much appreciate your response.
I actually did/had gone through to the best of my ability. I realize that the ChunkSize is identified via your import, but I can't seem to understand the rest of your header. Following WAVEfmt, you coded:
"10.00.00.00" for "16" for SubChunk Size
"01" for AudioFormat
"01" for Mono Channel
"80.3E.00.00" for "16000Hz" - which I expected "00.00.3E.80" or "3E.80.00.00" (based off my basic understanding of encoding)
You then have "00.7D.00.00" for Byte Rate
"04.00" for Bits per sample, which I don't understand? You are specifying 4 bits per sample?
Thanks greatly for any clarification you can offer...
Message 11 of 15
(1,726 Views)
some parameter doesn't affect (in my case).
here corrected:
Positions Sample Value Description
0 - 3 (0x52,0x49,0x46,0x46)"RIFF" ==> Marks the file as a riff file. Characters are each 1 byte long.
4 - 7 (0x32,0x4F,0x00,0x00) = 0x00004F32 = 20,274 ==> File size (integer) Size of the overall file - 8 bytes, in bytes (32-bit integer). Typically, you'd fill this in after creation.
8 -11 (0x57,0x41,0x56,0x45 = "WAVE") ==> File Type Header. For our purposes, it always equals "WAVE".
12-15 (0x66,0x6D,0x74,0x20 = "fmt ") ==> Format chunk marker. Includes trailing null
16-19 (0x10,0x00,0x00,0x00 = 0x00000010 = 16) ==> Length of format data as listed above
20-21(0x01,0x00 = 0x0001 = 1) ==> Type of format (1 is PCM) - 2 byte integer
22-23 (0x01,0x00 = 0x0001 = 1)  ==> 1 Number of Channels - 1 byte integer
24-27 (0x80,0x3E,0x00,0x00 = 0x00003E80 = 16,000 ) ==> Sample Rate - 32 byte integer. Common values are 44100 (CD), 48000 (DAT). Sample Rate = Number of Samples per second, or Hertz.
28-31 (0x00,0x7D,0x00,0x00 = 0x00007D00 = 32,000) ==> (Sample Rate * BitsPerSample * Channels) / 8 ==> (16000 * 16*1) /8 = 32,000
32-33 (0x02,0x00) = (16*1)/8 = 2 ==> where (BitsPerSample * Channels) / 8. 1 = 8 bit mono, 2 = 8 bit stereo/16 bit mono4 - 16 bit stereo
34-35 (0x00,0x10 = 0x0010 = 16 ) ==> Bits per sample
36-39 (0x64,0x61,0x74,0x61 = "data")  ==>where "data" chunk header. Marks the beginning of the data section.
40-43 (0x00,0x00,0x4F,0x0E = 22238) ==> NO Little Endian. File size (data) Size of the data section.
see vi modified.
Message 12 of 15
(1,718 Views)
This helps a lot!
On line 34-35, did you mean: "10.00" instead of "00.10" ?
And on line 40-43, what do you mean "NO Little Endian"?
I'm very grateful, thanks!
Message 13 of 15
(1,714 Views)
sorry, you are right (is in Little Endian)
do you know what Little Endian means?
please take a look here: https://en.wikipedia.org/wiki/Endianness
and the next is in Little Endian too, my mistake
and here: http://soundfile.sapp.org/doc/WaveFormat/
but don't worry about that
on line 40~43, no need to put use Big Endian
Message 14 of 15
(1,710 Views)
I understand the differences a little.. it's not my specialization.
Those lines HAVE TO BE little endian? I think my PCM is big endian... but I have no idea because my source is foreign. I've set everything else up the same way. I think the data is big endian too.
Message 15 of 15
(1,708 Views)
