Rational resampling filter changes data size?
I've noticed in the attached vi that changing the normalised bandwith or alias rejection in the FIR changes the size of the data!
I am using this function to change the size of a dataset from n to 100, so I need to know the size to calculated the M/L ratio. My alternative has been to increment the M or L in a while loop until data size = 100, so it's a bit messy and I'd like to know what the FIR is up to.
Graham
(2,405 Views)
Hi Graham,
The VI in question does some interpolation to the signal inputted to the X terminal, and then some filtering of that signal before it leaves the VI through a FIR filter. The fact this changes the array size should be expected.
Why do you need this VI over say the Interpolate1D.VI? If building the array from n to 100 is all that is needed to be done?
Also can you explain the M/L ratio your referred to? How is this important tot the task in hand?
Regards
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(2,358 Views)
