Raspberry Pi connection with Labview
Message 11 of 15
(1,336 Views)
That's good. Great job!
Message 12 of 15
(1,320 Views)
I still cannot connect via project, so NOT great!  I can connect thru Target Configuration because it has "Hostname or IP", "Username" and "Password" so I can use something beside the default for Raspberry Pi.
The LINX VI needs properties for username and password.
Message 13 of 15
(1,313 Views)
You will need someone to walk you through this virtually. I wish I could. Make sure you save your project folder and give it a name that makes sense. Once you do it, right-click on the project >> target and devices >> Linx >> (Your raspberry pi will pop up) and right click on it.
I think I've gotten into the same issue that you are having. I will have to connect my raspberry to and figure out how I solved it.
Message 14 of 15
(1,303 Views)
Any chance you followed up and connected to your raspberry and figured out how you solved this?
Message 15 of 15
(1,239 Views)
