Random unit vector (x0, y0, z0) generating
Yes, you are right ... I confused them.
Message 21 of 26
(1,742 Views)
Recall that the task was to generate a random unit vector in 3D.  3D implies 3 degrees of freedom, but "unit vector" constraint reduces the degrees of freedom by one -- it's not the sphere, but the surface of the sphere.  Hence two parameters (often called "theta" (0 to 2pi) and "phi" (0 to pi) suffice.  Note that phi does not need to go to two pi to get the "southern hemisphere".
Message 22 of 26
(1,725 Views)
In my interpretation (please see the poste above):
  • theta (zenith): 0 ... pi
  • phi (azimuth): 0 ... 2pi
Sure, zenith doesn't need to go over pi (if I properly understood your remark)
Message 23 of 26
(1,709 Views)
For Extra Credit, generate N points "randomly" distributed over the surface of a sphere.  In particular, the points should not "clump" at the equator or poles.  Hint -- theta (azimuth) is still uniformly distributed over 0 .. 2pi, and phi (elevation) still ranges from 0 .. pi (or -pi/2 to pi/2), but isn't quite uniform ...
Message 24 of 26
(1,703 Views)
Pavel -- I agree with you, the comment was meant for an earlier responder who commented on GerdW's post ...
BS
Message 25 of 26
(1,690 Views)
That is an excellent point Bob, and in my opinion it is not extra credit, but part of the original question!
Spoiler
theta = 2*pi*u
phi = acos(2*v-1)
where u and v are uniform over (0,1)
Message 26 of 26
(1,679 Views)
