Ramping voltage
How do i creat a ramp vi for voltage based on a voltage input and a sensing output? I am unable to find the ramp function that i saw previously.I anyoune can help please i could use a intervetion.
(2,846 Views)
In the pallettes you can search for VIs.  So simple tack it down and search for "ramp".
But the ramp pattern VI is under Signal Processing>Signal Generation>Ramp Pattern.vi
(2,840 Views)
