Ramp pattern
How do I get the time vs amplitude waveform in ramp pattern ?
It usually gives samples vs amplitude graph.
(2,980 Views)
Accepted by topic author bsunny
The Ramp Pattern just generates a 1D dbl array so obviously there is no timing information. You could use the Build Waveform function to add whatever dt you want.
(2,946 Views)
