RTM problems with 5.1.1
My Real Time Menu does not make it to the Executable in the installation disk.
Upon exporting strings, the RTM menu path is absolute.
Any suggestions ??
martin
(2,710 Views)
"Martin Eder" wrote in message news:3a351946@newsgroups.ni.com...
Any suggestions ??
I had exactly the same problem when building a Test Exectuve executable and it turned out that If the run-time menu happens to be stored in an LLB in the source code, then the menu won't show up in the application. This appears to be a 'feature' of 5.1.1.
Hope this helps
Keith Fuller
(2,710 Views)
Thanks for all the suggestions.
It appears that the RTM file does need to be saved outside of the llb. For App Builder to work Properly.
Martin
"Keith Fuller" wrote in message news:3a35e8e4@newsgroups.ni.com...
Any suggestions ??
5.1.1.
Hope this helps
Keith Fuller
(2,710 Views)
